Need Help, OBD1 Motor Into A OBD2 Car, CEL?
Old 02-22-2009, 12:40 PM
justfurebay's Avatar
Default Need Help, OBD1 Motor Into A OBD2 Car, CEL?
i'm trying to put a jdm b16a motor into me obd2 civic, the question is will i get a cel (which will cause me to fail inspections) beause of no crank angle sensor.
when i searched, i came up with the information that if i use a obd 1 distributor, with a obd1 ecu, such as the jdm p30 that came with the motor for a little extra, will i get no check engine light, because obd1 ecu's don't look for crank positions sensors?
is this what i'm looking for? http://technet.ff-squad.com/ckftrick.htm
thanks in advance.
Old 02-22-2009, 02:27 PM
Seagull Management
94EG8's Avatar
Default Re: Need Help, OBD1 Motor Into A OBD2 Car, CEL?
In the name of keeping this as simple as possible do the following:
-Use an OBD2 Distributor, alternator and fuel injectors.
-Perform the CKF fix you linked to.
-Use a USDM P30/P2T ECU
This should keep you legal, unless your state requires that the engine be the same year or newer than the car.
Old 02-22-2009, 04:59 PM
jdmf23accord's Avatar
so are you using your stock engine harness or the obd1 engine harness to make this work?
Old 02-22-2009, 05:12 PM
Seagull Management
94EG8's Avatar
As far as OBD2 civics go you have no choice but to use the OBD2 civic harness. OBD1 civic and all OBD1 and OBD2 integras use a 2 piece harness. OBD2 civics use a completely different 1 piece harness. The easiest way to do the swap is to use all OBD2 components on the engine so you don't have to cut and splice any connectors.
Edit, I completely forgot when I originally posted this the idea was to pass emissions. So on that note forget the OBD1 ECU bit, as it will not pass. Instead use an USDM OBD2 ECU and trick it into believe you have a CKF sensor.
Old 02-22-2009, 05:22 PM
Originally Posted by 94EG8
As far as OBD2 civics go you have no choice but to use the OBD2 civic harness. OBD1 civic and all OBD1 and OBD2 integras use a 2 piece harness. OBD2 civics use a completely different 1 piece harness. The easiest way to do the swap is to use all OBD2 components on the engine so you don't have to cut and splice any connectors, and then simply use an OBD1 ECU via a jumper harness inside.
so. +1 on converting to obd2 engine components with a obd1 ecu.
the reason i ask is because i paid extra for the jdm p30 ecu...so i was wondering if i should use it, or get a obd2 ecu...thanks.
Old 02-22-2009, 05:35 PM
gsrauto98's Avatar
If you use the obd1 ecu the thing they plug into your computer wont work. I have an obd1 ecu in my 98 civic which was obd2 and I just found a way around emissions.
Old 02-22-2009, 05:38 PM
so if you use a obd1 ecu will it pass? what did you do
Old 02-22-2009, 05:39 PM
Seagull Management
94EG8's Avatar
Correct OBD2 JDM ECUs work the same way as well, they will not communicate with the diagnostic port.
Old 02-22-2009, 05:41 PM
gsrauto98's Avatar
if you use an obd1 it will not pass. I registered my car in a relatives county where emissions is not required just safety inspection.
Old 02-22-2009, 05:45 PM
what country is that. so how do you get the plates and inspection
Old 02-22-2009, 06:55 PM
CivicSpoon's Avatar
gsrauto98 said County, not Country. But there isn't a county in NY state that I know of, that doesn't at least do OBD2 checking (needing an OBD2 ecu and having no check engine light codes).
Old 02-23-2009, 05:03 AM
in florida there is no inspections
Old 02-23-2009, 07:10 AM
USDMCIVICHATCH's Avatar
Ya, here in Florida things are still good...... I run all of my crap on obd1 ecus and with no cat or sometimes any exhaust at all besides open header, slammed with no carb stickers on anything, non dot lights etc..........sucks for you guys with inspections ha ha ha........only thing I hate is the mother****ing cops!!!!!
Old 02-23-2009, 07:39 AM
crazyz250's Avatar
your crank angle sensor runs off the same pulse as another sensor so do that hard wire link you put up and it takes care of that. Also use your obd1 dizzy and get a adaptor harness from rywire.com which makes your obd1 dizzy plug into an obd2 harness w/e having to screw around with dizzy housings. i did this putting an obd1 motor in an obd2 civic no CEL and it passes inspection no one even knew.
Old 02-23-2009, 06:19 PM
gsrauto98's Avatar
not country. county. and it is pike county, in missouri.
diviznrider
13
04-19-2019 01:38 PM
97DGreenEx
10-13-2006 06:21 PM
i3lazedx
07-13-2005 04:05 PM
mini-v-si
03-09-2004 08:11 PM
B18C1 '96 Coupe
05-21-2003 02:25 PM
Quick Reply: Need Help, OBD1 Motor Into A OBD2 Car, CEL?
