Failed ca bar
Failed ca bar
so today was my first go at it and i failed. i passed a smog test about 2 weeks ago but today i failed the evap test. could this be due to having a nissan gas cap on a honda? thanks..
Seagull Management
Re: Failed ca bar
Its part of the evap system, I really can't tell you anything specfic about, other than there are 2 vacuum hoses on it, one goes to the intake manifold, other goes to the charcoal canister.
Re: Failed ca bar
After the engine is warmed up (as signaled by the coolant temperature sensor, for one), the computer sends a signal to the purge solenoid valve to open. When the valve opens, vacuum from the throttle body/air intake is applied to the evap system's charcoal canister's diaphragm purge control valve, opening it. The stored fumes from the gas tank now get sucked into the engine's air intake. autozone.com has a decent description of the evap system in general under "emission controls" yada in its free online 85-95 Civic manual.
Re: Failed ca bar
No, that would be the IAB (intake air bypass) solenoid, found only on '94 - '01 GS-R/SiR-G engines. (I know you said yours is a '93, but also that its JDM, so i'll assume its a B18C engine that was produced in '93)
actually he didnt give me a paper. i failed on the evap test. they said i have a leak somewhere. so they didnt proceed with the test. i did pass a smog test earlier this month aswell..
Re: Failed ca bar
ifs ur gonna try to pass Bar wit a obd2 then good luck cuz its pretty tough..i failed 3x already wit my jdm gsr in 98 civic...readiness monitors ALL have to be complete, pass visual, emissions
i just got a used cat for my swap so hopefully i WILL finally pass cuz the one i have now is gettin weak causing me to fail emissions at idle wit high HCs
Re: Failed ca bar
After the engine is warmed up (as signaled by the coolant temperature sensor, for one), the computer sends a signal to the purge solenoid valve to open. When the valve opens, vacuum from the throttle body/air intake is applied to the evap system's charcoal canister's diaphragm purge control valve, opening it. The stored fumes from the gas tank now get sucked into the engine's air intake. Autozone.com has a decent description of the evap system in general under "emission controls" yada in its free online 84-95 Civic manual.
Dealing with my 91 Civic now trying to get it to pass emissions (not California's). I have little hope.
Re: Failed ca bar
That's for an ITR, but the procedures are the same. You need to get a USDM GSR intake mani that has the nipple for the EVAP purge solenoid. You'll also need a USDM GSR ECU like the above poster said. You can bypass the CKF sensor by performing this trick:
http://ff-squad.com/wp/?p=309
Re: Failed ca bar
no codes.
Re: Failed ca bar
i have a JDM p72 and the inspector said its fine. "As long as its stamped p72 i dont care" that is what he told me. and he also asked me if my intake mani was JDM or USDM cause he couldnt tell even with looking at the diagram they use.
