EJ1 Door Replaced with EG6 need help.
1 Post
I need help again guys.. I got my car back from the shop but they didnt take care of the wiring for me since I bought an eg6 door. Little did i think about it but the lock actuator, and the window motor are all two wire, while the US harness is setup for 4 wire for the actuator and the window motor...
the JDM actuator has a Yellow/red, and white and red
The USDM has white, yellow, black, and blue.
And the JDM Power window motor has 2 blue wires, The usdm harness has red/green, red/yellow, Blue, and black..
I dont know where to start with this. Im not the best at electrical but if you guys have any advice i can make due! thanks in advance.
Re: EJ1 Door Replaced with EG6 need help.
well one thing is its a jdm door correct well if its on your drivers side then in japan that is actually the passenger door ie having less wires and such since the master control would be the opposite door
so if you have your old door still i would swap the guts with your new door to make it easy
be professional
You just take the old door harness and swap it into the new door. Do the same with the regulator, latch, actuator, etc.
Kyle700
12-10-2014 11:32 AM
