no heat!
no heat!
i have a 1992 honda civic hatchback cx. i have no heat at all. the fuze is good! the tester diesnt work on it but once i switched and put it in another spot it worked!?!?! never the heat all the way up i still got nothing coming out. is this a bad blower? that would be sweet if you could help me out! thanks ........
be professional
Re: no heat!
"No heat" is not descriptive at all.
Is the blower blowing but the air coming out of the vents never heats up? Or does the blower do nothing when you slide the fan switch? Does it work on the highest speed but not on lower speeds? Does the temperature gauge warm up to normal operating temperature (between 1/3 and 1/2 of the way between C and H), or does it indicate cold all of the time?
Have you checked the coolant level in the radiator?
Re: no heat!
no air at all! 1 and 2 never woeked only 3 and 4 did but now im getting nothing on eather 1 2 3 or 4 yea my car is not over or under heating at all. yea its full
be professional
Re: no heat!
That's different from "no heat" then.
Then the blower resistor was bad to begin with.
Check for power at the blower motor plug with the switch set to 4. If you're getting power, the motor is bad.
SpoolnByYou
34
07-06-2006 04:42 PM
