Connecting Vtec at the Solinoied.
Ok i have d6 and a4 In the ecu plugs but which one goes where?
On the Vtec Solinoied theres the 1 wire Plug and theres the 2 wire one(like the water temp,IACV, Evap Sol ect.) Wich one goes to what?
Re: Connecting Vtec at the Solinoied.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
everything you need to know the wiring is somewhere towards the bottom of op's post
i am assuming when your saying the vtec solenoid you are including the oil pressure sensor as well, because there is only one connector that goes to the solenoid. But the oil pressure sensor has the two wire plug the extra wire just goes to a ground on your block. The solenoid has the single wire. If i was home i would give you a link to a write up on it but i can't find it right know, but it should be pretty easy.
Arthas
04-23-2012 01:30 PM
juicy.koreans.suck
12-25-2001 01:54 PM
