questions about disk brake swap.
Ok so now i have my car totally tore apart. and i find my self confused as to what i can reuse off of my 95 ej1
here is the setup
Ok i got 01 Teg LX trailing arms complete with rear diskbrakes and ebrake cable and Lower control arm...
Now when i took off my stock trailing arm i find that the Lower control arm is not bent like the teg one.
Question #1 : Do i reuse my stock lower Control arm?
Question #2 : Do i reuse my stock ebrake cable? or the 01 teg one?
Thanks for your time.
here is the setup
Re: questions about disk brake swap.
us your control arms. the teg ones will work but you will have to get rear teg struts. the mounting points are wider on the teg. you will also need to use the teg e brake cables.
yeah. use your civic arms. you want to try to use as much as possible from the integra. e brake cable, brake lines, etc.
som3on3_10
03-16-2008 11:55 PM
paulzy
11-16-2001 02:00 PM
