Help with Heater Core
New User
Ok so the heater core is leaking causing that aspy steam coming through the vents. It's fogging up the windshield and leaving a film as well as leaving a real nasty coolant smell. The bigger problem is the fogging because its causing a hazard with seeing out the window because of the fog, even in the middle of the day when it's 60 degrees out.
What would be the best/easiest solution. Can I bypass the heater core without removing the dash so it stops fogging? It's warm now so we don't need the heater. How hard is it to just replace the damn thing? How much does a heater core normally go for? I tried searching but couldn't find anything useful.
Any help would be GREATLY appreciated.
