when cleaning iacv?
when cleaning iacv?
ok when i un-boly my iacv to clean it is there going to be coolant coming out or know ?
also wile im at it, i have a bouncy idle after car warms up, would it be bleeding system or iacv or what else ?
Re: when cleaning iacv?
If you take the iacv off and unhook everything then yes. you should be able to unbolt it turn it enough to spray the crap out of it with cleaner and give it a good scrub. Then once that is all back together see where you stand with your idle you could also ave a problem with the fitv if your car has one
no vacuum leaks, and no cel on, just sometimes when engine warms up {NEW ENGINE} all brand new rebuilt,} it will have a slow small jumpy idle.
ok so i will do that to the iacv
also my bleeder is rght by my upper radiator hose ?
and what goes with the fitv ? also spray some carb cleaner ?
easy way to bleed the coolent is with a cold engine pop off the rad cap, fill it up and start the car up and let it run for 15-20 minutes til no more bubbles. top off coolent as necessary.
so i should use what ?? brake cleaner ??
also so just pop rad cap off, fill to top, run car , and what the coolant wont spill all over the place ?
Small amount of fluid will leak, nothing to worry about. I used carb cleaner to clean mine but you can also use that Intake Manifold cleaner they sell at Autozone.
so if i clen iacv and bleedsystem, and still weird idle get back to u guys ""??
also can i just un-bolt the iacv and spray cleaner ?but leave hoses attched ?
its rebuilt motor 250miles ago, all goo cleaned rom verything so i dont know why it would be dirty.
VTechLivin94
15
03-29-2013 06:52 AM
the.hamburglar
05-10-2007 08:46 PM
c for sea
22
09-19-2006 11:02 PM
