Which motor mounts?
Which motor mounts?
I just bought a b18b LS motor and i am going to drop it into my 93' sol. Im def. going to buy the hasport solid mounts but need to know exactly wich ones to buy. I think i need the EGB1 Hasport kit And also, Hasport Shift Linkage 92-00 Civic w/ B Series motor. Correct me if im wrong
Re: Wich motor mounts?
Why not just use the regular mounts that came with the engine? Even if you didn't get any with it go find some for cheap. They will work fine, and make you happier for the most part. Solid mounts make your whole car rattle like a POS. You would need the rear T mount and the driver side mount, as well as both side torque mounts if you don't get them with the swap. As for the linkage, the HaSport one you mentioned will not work as the del sol has a much different linkage setup. You will need a del sol VTEC (B16 del sol) linkage to make this all work. Good luck!
Thanks for the reply. But my friend has a EP3 and before he got his solid mounts he had wheel hop wen he would launch. After he dropped them in it was just burnouts no wheel hop. How is this not better then stock mounts?
Re: Which motor mounts?
just get stock mounts, a b series did come in a sol. i dont get why people like spending $300+ on mounts. when they have the option of using something that doesnt make as much noise or vibrate as much.
with the money you save using stock mounts you could put energy suspension inserts in and get a traction bar. this will eliminate wheel hop and give you better traction.
It all depends on what you are using the car for. For a stock B18B1 daily driver with 142 hp, you will be much happier if you go with stock mounts. If you plan to boost it in the near future, or maybe go NA LS/VTEC, then take a look at something a little harder. Does your friends car with the mounts vibrate the hell out of you? I know I've never ridden in one that didn't...
Ok so these mounts will support my LS ?
http://cgi.ebay.com/ebaymotors/93-97...61110004r27077
Yeah that's kind of important to mention...so if you want to go with the HaSport mounts the ones you listed would work fine. I would not buy EBAY junk as you get what you pay for. You will still need the shift linkage from the Del Sol VTEC as it is the only one that fits, unless HaSport makes a Del Sol linkage a well. Good luck!
i dont know about those egay mounts. i wouldnt trust them. but they sure are cheap. i used stock mounts on my da with inserts it was boosted and it was fine. i also used a revhard tractionbar.
j-villani
09-27-2012 01:27 PM
bluedelsol
06-03-2003 06:14 PM
