Engine won't start, Key turns No ignition
This happened three years ago and then never happened so i didnt fix it.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/car-didnt-start-no-crank-when-turned-over-1761874/
This month it has happened 3x. It usually happens when i make a short trip, park, and try restarting again. When i run into this, i usually press on the accelerator 3/4's and the car somehow starts.
The key turns, I hear a click noise and the fuel pump. But the engine won't crank.
I talked to some friends and they said starter. Today it happened at a gas station, talked to a mechanic and he said replace the ignition wires.
What are your thoughts?
Thanks!
Thanks!
Re: Engine won't start, Key turns No ignition
Intermittent problems are tricky. Sounds like a bad starter. Also check the ground wire on the transmission, as well as the battery ground wire.
immrtaltchnq
09-22-2008 05:36 PM
eg686
06-10-2006 12:58 AM
