b16a motor trouble
b16a motor trouble
ok so i have just put my new motor in its a b16a now the block has been decked and the head has beeen shaved timing is dead on and its runs like **** no power feels sluggish vtec doesnt seem to be there but no check engine light or nothing oil is full also. i am running an obd0 manifold with obd1 map sensor also it idles ok idle surge which is because of my iac but besides that anyone have any answers now i havent done a valve adjustment but it has brand new valves in i know this has valve adjustment written all over it but that much loss in power? and it sounds like a ****in subaru at bout 1000 to 4000 rpm under a load but not at idle
Re: b16a motor trouble
Thats just retarded. New valves and you didn't do an adjustment?
That thing should have CEL's all over by the sounds of it. Fix what you know needs to be done before you ask what it could be.
Check to make sure none of your spark plug wires are mixed around. Also check to make sure the injector plugs are on the right injectors and and check to make sure your tps and map plugs are mixed up.
ok so i did a compression test today and cyl#1 220 #2 220 #3 75 #4 130 how gay we did a leakdown but i dont understand why when you fill the 3rd cyl with air it goes out the throttle body and comes out of cylinder 4? anything
Well, lets see here. When cylinder 3 is at TDC on compression stoke(which is what you should have it at to do a leak down) cylinder 4 should be at the bottom of the intake stroke wich would mean the intake valve would be open. I guess a possibility would be a bad leak between the 2 cylinders.
Fallriverb16
14
05-25-2016 04:02 AM
hatcht9x
16
11-15-2009 08:46 AM
