LS harness question
Re: LS harness question
Your gonna have to do some wiring. I would stick with the cx harness. The injector clips are different and the dizzy is diff. IDK what else is i try not to **** with obd2
EK has 1 piece harness. Tegs have 2 piece harnesses that "break" at the shock tower. Its only an LS so just use the Civic harness.
EDIT: As posted above, yes you will need to convert a couple plugs or just run an obd2 dizzy. You also need a jumper harness if the ECU is OBD1.
hatcht9x
11
01-22-2012 08:36 AM
bigluelok
06-25-2007 12:12 PM
