95 Civic EX Cluster swapped into 92 civic CX Hatch and now blinkers dont work! HELP!
Like the title says. Swapped in a 95 EX cluster and now the blinkers or hazards dont work. I put the old cluster back in and the blinkers and hazards still dont work. I replaced the turn signal hazard relay and still the same thing. I checked all fuses underhood and underdash and they are all good. Any help is appreciated!
Re: 95 Civic EX Cluster swapped into 92 civic CX Hatch and now blinkers dont work! H
Make sure you check that all the cables are conected. Or maybe you pulled them out too much
Check. Everything is plugged in. The speedo, odometer, fuel, and temp gauges all work fine. When I push the hazard switch in my radio shuts off though. I think my hazard switch is fried...
OK, I replaced the hazard switch and the nultifunction turn signal switch on the steering column. There was a 7.5 amp fuse that was blown in the underhood fuse box. I replaced it. My blinkers still dont work and when I turn the key off and take it out the engine still runs! I have to depress the hazard switch to get the engine to turn off.
Anyone help here?
Anyone help here?
1baddturbosi
12-15-2006 06:52 AM
