Rear control arms...
New User
installing these rear/lower control arms
i already did an alignment when i dropped my car 2" two weeks ago. will i need to throw it on the alignment rack again after the control arms? will it change dramatically? i'm only messing with the strut really. i'm not thinking that it'll interfer too much with the alignment. any comments?
Re: Rear control arms...
there's a chance that you may need an aligment after the install. even if the length is the same, i'm guessing that your old LCA's had old bushings in it and the new LCA's may change that.
drive it around after and see how it feels. keep an eye on your rear tires to see if they're out of toe or not.
If the old bushings are rotted, I could see the alignment being out of whack. Some aftermarket LCAs are different lengths than stock to help correct camber due to lowering your car, so maybe that could also change the alignment.
And about the bushings in the Skunk2s, they may be better than stock, I won't argue that. However, there are the Energy Suspension urethane bushings for OEM LCAs...
New User
dr_latino999
12
07-18-2007 10:17 AM
What good does swapping right rear upper control arms for left rear upper control arms do for caster
ESCALVANTE
11
03-12-2002 06:17 PM
