Speedometer not working
Ok, So I replaced my speed sensor and my speedometer still doesnt work can anyone help me out with this problem PLZ
Re: Speedometer not working
unplug the plug from it, then pop out all the pins and clean them with something that can srach up the surfes of the conecting points, that will fix it
I will try that tomorrow it just started raining and I ccant get my car in the garage because my wife blocked it thanks though bro I will let you know how it turns out aaight
alright, but yeah im 99% sure thats it, it have happened to me two times and 1 to my friend, it did work befor tho right, then it just stared going off and on when you are driving?
Yes it was working before and then it fluctuated between 40 and 80 then just quit working all together . What makes it get dirty though? I was told that it could be my ECU causing it but I dont really know ?
Yes I have a CEL but it is on for another reason BECAUSE OF THE CRANK ANGLE SENSOR . It is a 96 with a ls vtec with b16 pistons and a stock gsr head . The check engine light has been on every since the first time I got my original GSR rebuilt IT IS JUST A LONG STORY THAT I DONT LIKE TALKING ABOUT BECAUSE I HAVE SPENT SO MUCH MONEY ON THIS CAR !
Ok So I cleaned off the connections and i forgot the order that they go back on can anyone help me out with this . I am talking about the connections that go to the speed sensor HELP ME PLZ
I have a civic dx which I am currently trying ot get ready for safety...
The last thing I need to fix is the speedometer, I only works when it wants to? Sometimes it works fine without bouncing around or anything and sometimes it simply reads 0. Any ideas on what I should look at first?
Thanks
Thanks
theres a small gear in the transmission that makes the speedo sensor spin and work.. sometimes that gear can be worn or missing teeth causing the speedo to not work at all or work randomly or bounce the needle around randomly.. if the pin cleaning doesnt work that would be the next spot to look
Ladysman_civic
12
02-27-2003 11:36 AM
