HELP! Problem with lighting
Yesterday my car got rained on, Window was down for 2-3 minutes..
Now my dash lights dont work ( cluster and ac area ) Nor do my Tail lights or corner lights up front
I have brake light and head lights i checked all fuses, all are fine, Anyone know the problem? Any help is appriciated
Re: HELP! Problem with lighting
Checked them with a fuse tester with power on and with a meter to be 100% sure all fuses were working properly i was wondering if it may have been a dimmer switch or idk
Yeah i checked that one according to my book as it matches all of the discription, i even replaced that fuse, still doesnt work
Pry the dimmer switch out of the dash, unplug the connector, turn the parking lights ON, and check whether you measure 12V at the pin for the Red/Black wire in the wire harness connector to body ground. If not, check whether you measure 12V to body ground at the battery side terminal of fuse 19 when the parking lights are ON.
I just checked dimmer switch. no power, i even grounded to the body I pulled fuse #13 no power even to fuse box
so any idea?
so any idea?
Yeah, its the one that says " instrument lights, tail lights, parking lights"
yeah i turned it on both, first one and then second one, because there on when highlights are on
Gatschet
23
08-25-2021 10:35 AM
Luder88
Lighting
02-02-2009 06:51 AM
