Parking Brake Adjust
Ok....so I feel like a total dumbass for having to ask this but, to be honest I've searched online, on honda-tech, in manuals, and on this alldata system that has like a manual for every car made on its system.
I cannot for the life of me figure out how to adjust the e-brake on my 93 del sol S. I just got done replacing the rear shoes (drums in the back) and now the e-brake needs to be adjusted. The pads are working great, I've got all the brakes bled and properly adjusted but I just have no e-brake, it pulls up all the way.
Everything I've come across says that there is a little adjuster nut and mechanism under the console, which apparently del sols do not have. So I went underneath the car and moved an exhaust heatshield out of the way and found the spot where the two cables come together. That mechanism is working fine, it engages all the way when pulling the e-brake, and theres no adjuster there either. So we've come to the conclusion that it needs to be adjusted at the drums, but I can't think of any way to adjust them in there either, unless I just missed something.
Re: Parking Brake Adjust
I'll take a look at that tomorrow, anythings worth a look.
I adjusted that nut, and tightened it down all the way but it didn't do anything. the problem has to be further back in the drums I think. looks like i'll be taking those puppies off again soon....ugh...
on the back side of the drums there is a gear that is inbetween the drum pads that you can loosen or tighten to set the resting position of the drums pads.
yeah but the drum pads are adjusted just fine, its only the parking brake that is the problem, and it has nothing to do with the cable, it didn't magically wear out all of a sudden when i replaced the brake shoes.
Looks like I'm on my own until I have an oppurtunity to take the drums off again cuz this is getting me nowhere.
Im having the same issue on a EJ1...
i replaced the wheel cylinder on the passenger side, the drum on the passenger side and the shoes on both drums. i put everything back together (went by my chiltons and some random civic forum threads) and the foot brake works fantastic but the parking brake does not grab hard enuff to keep the car still on even a small incline. im having to leave it in gear to park it.
i HAVE adjusted the "self adjuster" ratcheting mechanism just below the wheel cylinder on both sides.
i HAVE adjusted the nut behind the parking brake inside the car. the handle comes up about 9 clicks to tight.
i reinstalled the parking brake lever (inside the hub) the only way it would go. i only did one side at a time so i know they r not switched.
i pulled off the drum and watched the shoes' behavior when the ebrake is pulled. its not even at all. when the handbrake is applied, only the upper end of the front shoe moves out. everything else stays relatively in place.
i have driven it to try to allow the pads to seat and the self adjuster to adjmust properly but to no avail. still no parking brake!!
HELP!
HELP!
must have been only on the 93's then, because my 94, 95, and 96 sols all had the adjuster under the arm rest as well as my 96dx. Ill look again marrow at my 95 (its gutted ATM) and see if i can find something out for you.
HairyHarry
12
07-09-2019 11:51 AM
Angel987
01-23-2018 11:05 AM
Nave43
46
03-26-2015 03:01 PM
