Better brakes?
Re: Better brakes?
Axis pads front and rear, oh do you have read disc?
Unless you have big HP you don't need to do to much if you have a Si. Even from 140+mph our drag Si, it would stop fine with Brembo blanks and Axis pads. Driver said they had a good cold bite. Made a mess out of the wheels when it was street driven, but stopped great.
Re: Better brakes?
I want to use it for street mostly and sometimes on the track. Should i just get better pads and im set? Not looking to spend alot. $300 the most haha
Re: Better brakes?
I dont know if hatches don't have rear disk brakes. Si hatchbacks come with rear disk brakes I believe. My bro's si hatch had rear disk brakes. DOn't know if it was factory setting though, so I could be wrong.
Re: Better brakes?
OP just get better pads. I guess your's isn't an Si
I use Bendix ceramic's on my 05 LegacyGT.
Re: Better brakes?
I beg to differ. Even with a new prop valve and MS, most of your braking is still in front. It does help, but not worth the hassle in my opinion. Might as well get some better tires, they'll make a bigger difference
Re: Better brakes?
jhonda239- even with rear disk the front still does the most breaking...
you can do a conversion with or w/o one but to get the best from you set up you need one.
Re: Better brakes?
Thanks guys. I think ill just get brembo blanks and hawks hps. hopefully that'll do me good for street and track from time to time
Re: Better brakes?
Seagull Management
Re: Better brakes?
Integra front brakes, theres your answer. Use a set of front knuckles and calipers from any '94 - '01 Integra, Master cylinder and brake booster from a non-abs '94 - '01 Integra and prop valve from an non ABS integra (this can come from a '90 - '93). Rear discs are nice from a maintence and cosmetic perspective, but they really don't add anything in terms of braking.
spoonlongblock
Honda Civic (2006 - 2015)
03-28-2006 07:46 AM
