Correct firing order with pics for obd1 b series in a eg coupe? Need pics to know
I cant figure out the firing order starting from the dizzy side
The haynes book sucks and just tells the firing order it does not show a pic to make sure you have it right
Need to know what cylinder goes where
top left
top right
bottom left
bottom right
top left
top right
bottom left
bottom right
Re: Correct firing order with pics for obd1 b series in a eg coupe? Need pics to know
I have it like that ands its still not starting timing is dead on it gets spark, compression and fuel it just turns over....
Is the CEL ON?
Are the fuel injector connectors installed in the wrong order?
Is spark bright white/bluish or weak orange?
Were any sensor connectors swapped?
Did you replace anything on your car when you took the wires off? ex. distributor?
thats the same siring order for a dseries i have a b not d
bright white
no just the problem using a 2g si/ex manual harness on a b18
Fried one ecu mixing the iat and the egr wire but nothing else is wrong
nope but what should the ohm reading be between?
If you don't measure battery voltage at the YEL/BLK wire terminal of each fuel injector connector with the key turned to ON(II), then you have found the problem.
Is fuse 31 under the hood blown?
