B18B swap in auto EG, a few questions...
1 Post
So I'm gunna do a B18B swap out of a 94 Integra into my buddy's 93 dx EG hatch. I have everything, I mean everything, from the Integra and of course the motor and trans are still in the EG. The EG is an auto and the B18B is a stick so there is an auto to manual conversion as well. Lol, good times.
Anyway, my questions I can't seem to find using the search is: what is the company that makes the aftermarket mount for the tranny so I don't have to cut and weld the frame rail braket? Is it innovative or something?
And for sure the LS harness will plug right in to the EG shock tower harness and the LS ecu will plug right into the EG ecu plugs, correct?
Also, will all the mounts that bolt to the motor and trans on the LS work and then rubber mounts on the chassis from the D15 will work as well right? Or is there a couple that I need to swap like on an EK?
Thanks for the help.
1 Post
Re: B18B swap in auto EG, a few questions...
thanks!
Oh, I found the info on the mount, Innovative, Hasport, and another no name company make them for the auto to manual swap.
Still curious about the other two questions though. Thanks!
Seagull Management
Yes the ECU plugs right in, and so does the engine harness. The map sensor on your buddies hatch is going to be firewall mounted (its attached to the fuel filter bracket), unplug it from that map sensor and connect the harness that went to it to the throttlebody mounted map sensor on the B18B, disregard the map sensor plug on the teg harness.
Resident Gearhead
That is exactly correct
Many people get confused about which MAP connector to use.
I am mystified why Honda decided to use and external MAP sensor just for the DX (in the US).
I just did this same conversion. conversion mount from innovative, $150 shipped. Lines, pedals, shift linkage, and the rest of the motor mounts, you will need from the teg.
Let me know if you have any questions. I have some secrets that will help make everything easier if you've never done the conversion before.
b15
13
01-16-2010 04:47 AM
