car dosent like to start sometimes
ok heres the deal my 94 EX with stock motor occasionally dosent start right away sometimes it starts then dies and then it starts again it never stall is traffic of anything the idle sometimes is really low other than that no other obvious issues with it.
my guesses are the fuel pump or the regulator btw my fuel filter is new and my car has 192K miles
thanks for any imput
Re: car dosent like to start sometimes
all tune up stuff is new
no CELs
i have no idea if the FITV or the IACV have been changed out
no CELs
bump anyone also it didnt start doing this until the weather changed
im gonna try another IACV and a FPR i have lying around and see what happens
Maybe whoever installed your fuel filter was the first individual to successfully install a fuel filter backwards on a Honda LOL. J/K, I've seen it a few times on some domestics and NO I did not do it.
I'm almost positive that it is weak solder joints on the main relay. Take the main relay out, pop the cover off, and re-solder all of the solder points on it. They may not appear weak, but underneath that blob of solder there is probably a tiny tiny gap between the blob of solder and the pin that it is soldered too, and the hot temperatures are causing slight expansion of the solder and the connection is then lost.
This same exact (every single symptom you listed) thing happened to me last summer. I re-soldered the solder points in the main relay and I haven't had the problem since.
I would say coolant temp sensor. Mine went bad before didnt throw a CEL, But car woudl take forever to start sometimes, then it would start up and die and idle really low.
susuking
Honda Civic (2001 - 2005)
03-18-2007 08:40 AM
racingrex
11-06-2003 04:46 PM
