Motor mounts for a GSR into an EK
Just a few questions, swapping a 96 GSR into a 96 EK, so I'm lookin' for motor mounts.
Are Integra B series motor mounts the same as EK B series motor mounts? If not are any of them interchangeable?
I already have the rear mount, I just need the upper tranny and upper driverside. Theres a guy selling B16 motor mounts from an Integra and claims they are interchangeable to an EK. Is it true?
I'm only lookin' for OEM mounts due to insufficient funds, I cannot afford Innovative/Hasport mounts like many other's are just plainly suggesting.
Re: Motor mounts for a GSR into an EK
-99 civic si rear engine bracket
honda pn#-50827-S04-N10
-96-00 Civic(all models) manual upper tranny bracket
-96-00 Civic(all models) driver side upper engine bracket
-99-00 Civic si driver side engine mount(2 bolt pattern mount bolted on block behind timing cover) honda pn#-11910-P30-000
-94-01 integra or 99-00 civic si manual passenger side transmission vibration mount(3 bolt pattern)
-94-01 Integra driver side block vibration mount(4 bolt pattern, ac comp mounts to this mount)
Hope this helps
Hope this helps
Hope this helps
Hope this helps
And the vibration mounts are also known as lower mounts correct?
So I guess all I have to worry about is the 99-00 Si timing belt cover mount.
So you're saying I can use my stock D series upper transmission and upper driverside mounts? Assuming so since it says all models.
D series upper drive side mount bracket will work(its the 3 hole bracket that mount to the rubber tripod mount already on the car)
Usually the hard one to find on the street is the 99-00 civic si mount behind the tb cover.
PN# 11910-P30-000
its about $49 new on www.hondapartscheap.com
They new oem parts and its the cheapest place I found so far online for oem parts, copy and past the pn# I gave you and goto the site, it'll show to the pics so you have an idea what it looks like.
Hope this helps
Hope this helps
anybody ever try using a Gsr block mount? instead of having the 2 studs it has 3. i wonder if it would make the engine sit differently.
^^ dont think that one will work..it might tweak the motor out of place.
BUT are u planning on keeping ur A/C?
in that case u need a CRV A/C bracket.
Your D-Series A/C Compressor bolts right onto it. also for power steering, if u have a 99GSR pump u can re-use ur D-series stuff
crazykid9137
07-22-2005 11:35 PM
electric-boost
05-10-2004 06:57 PM
