wiring issue clock and and cd player no constant power
cd player was working but slidin in and out of the holder about a half inch so i pulled the cd player out to fix it. after fixing it the cd player wasnt working so i pulled it back out and sure enough the constanst power wire some how pulled out of the back of the cd player. i plugged it back in but nothin worked so i checked to see if it had power with a test light. nothin, then i check fuses and all was good. so i started the car and the clock had reset but it was dim, i turned the head lights on and it looked off but it was just really dim. i when to the store and the clock resets evertime the car is turned off.
Re: wiring issue clock and and cd player no constant power
look at the under the hood fuse box, check your BACK UP fuse. I was having the same issues in my EG, fixed it right up
well check all the other wires as well there is a constant power and a switch 12 v if either one came un down= no deck
dude you freakin rock...now i wish you could fix the 300 dollar flipout screen. it wont come on. i double check the wiring and the fuse built in is fine. crap
no prob man, took me a few days of searching then BOOM i found it, quick fuse change and all was well
immrtaltchnq
Audio / Security / Video
07-18-2009 10:01 PM
jdmbeegee
10-17-2006 08:05 PM
Yoshiemaster
Honda Civic (2001 - 2005)
08-12-2006 01:12 PM
