d16 injectors question
Re: d16 injectors question
hmmm i belive stock is 240cc`s not 100 percent sure but back to the other question im runnin 450cc`s in my boosted d16z6 they wont max out !
what turbo are you running im running a t25 garrett runnin 12 psi
and with my mods the car is pushin over 200 horse 450 is your best bet.
i have a greddy turbo kit with a td04-15g i think turbo
nice 200+, i wanna try and push that but we'll see how it goes
just get some dsm blue tops.
i have one friend running a t25 with 450cc dsm at 8 psi - dunno what he dynoed at, stock d16y8
i have another friend running a t25 with 450cc dsm at 20 psi - dynoed at 240 hp 235 ft/lb tq d16z6 vitara build
what im saying is, dsm 450's will get the job done
ya its that best way to go
and nice nice the t25`s are good because there is barly and turbo lag
my build is
d16z6
y8 cam out of a d16y8
t25 garrett turbo 12 pounds
turbo xs bov
aem front mount
3 inch dp
straight pipe no cat no res.
450cc injectors
aftermarket fuel pump
V-TEC hahaha
my build is
d16z6
turbo xs bov
aem front mount
3 inch dp
450cc injectors
V-TEC hahaha
my build is
d16z6
turbo xs bov
aem front mount
3 inch dp
450cc injectors
V-TEC hahaha
my build is
d16z6
turbo xs bov
aem front mount
3 inch dp
450cc injectors
V-TEC hahaha
my friends dyno sheet was 240hp at 3k rpms. thats a fast spool for a 1.6
i have a vitara build going.
i need a z6 crank and rods to get it near completion
i was gonna get tuner toys rods, but they out of business so eagle it will be.
also, you gonna keep the y8 cam? i heard it is cut on a d15 index and the z6 cam is a better choice
D series VTEC injectors are the same part as B series of the same OBD generation (240CC). D series non VTEC and VTEC-E injectors are 190CC.
the black top and blue top dsm injectors are both 450cc injectors. the difference between the two is that the blue top is out of the dsm 1g turbos and features a single spray style pintle. while the black top is out of the 2g turbos and features a superior dual spray style pintle. the black top is actually better.
http://www.b18c5eg.com/injectors.htm
So which cam is better, the z6 cam or y8? I've heard the y8 cam was cut a few degrees more to create more combustion than the z6 cam. Ive got a z6 right not but thought bout changing the head over to a y8 head. Also the y8 intake is bigger with shorter runners, whats yalls thought on it? just curious on which route to go with
just wondering if u can swap the intake out of a y8 fuel rail and all into a d16z6 for my del sol all stock cept i gota stainless exhaust manifold and 2"1/4 stainless exhaust all the way to the back...bought this manifole off wat i think was a y8 for 40$plus i got his valve cover...gd deal or no??
tnx
tnx
