installing my jdm coilovers?
Re: installing my jdm coilovers?
huh?
well the bigger spring will go on front due to the weght.
are they seperate? or one peice? if one they can only go 1 way. the shock are different.
i installed it with my boi..and its adjustable so the back is adjusted as low as it can but its still sitting high..the front is adjusted *** high as it can but its still low.. im thinking that they are on the wrong ends?
They are not JDM. they are cheap ebays and will bounce ungodly. But they should be the same length you put them on wrong or something
its adjustable so the back is adjusted as low as it can but its still sitting high..the front is adjusted *** high as it can but its still low.. im thinking that they are on the wrong ends? and ya they do bounce kinda alot
thoses arent jdm buddy,
yes switch the springs around.
what i have noted on the egay coilovers there are the same size, for both. so if this doent work youve got other problems
Crazy Honda Guy
Do you even know what JDM means???
Japan Domestic Market
So, if you were to buy a car in Japan that had a factory option or any part from that car, it would be considered JDM!!!
Don't fall for all the bullshit that is sold online and ebay where people throw the term out, just to sell junk. This is a big heads up to all the noobies out there.
huh?
well i guess you might as well you have peice of **** coil overs and its always going to ride like ****, noithing you can do,
put your stock springs back on and save up for some skunk2s or somthing and be happy with you what you spent your money on.
anyone have experience with omni power version of adjustable coilover sleeves? thinking about getting them to have while i save for some legit teins
im jus trying to have my car lowered without being bouncy at all. Ive been looking at the suspension package on modacar.com that has the adjustable springs with rear lower control arms and front camber kit. That way i can have a lowered car with no camber problems for a while and then get the tein super street coilovers later down the line. That way ill have the control arms and front camber parts and then can just swap out the sleeves for real coilovers. And for the price your not paying much more than you would if you bought just the rear lower control arms and the front camber kit. Basically you get the omni power sleeves for the same price as the generic ebay sleeves which i feel is quite a deal ha
