car wont start need help
i cant get my car to start! I checked to see if it was throwing any codes an nothing came up, i talked to a local shop they said to try the distributor so i change that out an nothing worked still, i checked my fuel pump that is fine, i have power going into my ecu but no power coming out could that be the problem? If you have any ideas that would be helpful. Oh an i have a d16z6 block, with a d15 head, built block, and boosted. I changed out my suspension an after i got done car wouldnt run no more
Re: car wont start need help
Does the engine crank but not fire?
Did you forget to reconnect the ground wires?
Do you have spark and does the fuel pump prime for 2 seconds when the key is turned to ON(II)?
Does the CEL work? It should go on for 2 seconds and then off when the key is turned to ON(II)?
DeDonDeRosa
12-01-2003 04:31 PM
