which wideband 02 to get and how to install?
i was told to invest in a wide band 02 sensor and ive been looking and reading up on it. but still dont quite understand what its purpose would be for my car. also what brand should i get because i read that they die out after a while what would be a reliable one to get. i have the tack already but not the sensor the previous owner never got around to getting one. also how would you install the 02 sensor?
thanks
thanks
Re: which wideband 02 to get and how to install?
AEM UEGO Wideband... they run about $260 for the digital one here in Canada
Replace it with your o2 sensor (engine light will come on) in your header/exhaust or get a new bung welded in behind the o2.
The purpose is to tell you your Air/Fuel ratio. To tell if your running to lean or too rich. If your motor is close to stock dont waste your money, if your running cams/bigger injectors or anything major you should get a wideband.
crxforum
02-03-2005 09:29 AM
