removing Honda emblem on SI
Re: removing Honda emblem on SI (RAMSi)
Just use a flat head screwdriver and carefully pry/pop it off...be careful not to crack the emblem or scratch the base of the grille unless you don't care.
k, pop the hood and take out all the little pop pins across the top of the bumper between the headlights. There are 2 8mm screws in each wheel well. After you pull those out, you can tilt the bumper forward enough to unscrew the H off the grille. You might want to put a cloth on each fender, cause the edge of the bumper tends to rest on them. Good luck with it. You'll love it without the H. Right now my car only has the H on the trunklid.
Re: removing Honda emblem on SI (RacerSi)
New User
on the back emblem use doubled up dental floss. You can assure yourself no scratches that way and its very easy. Also use it to shave off the si or civic decal which I did as soon as i got my si.
B16HelpMe
03-04-2007 06:52 PM
micheltan
07-13-2006 09:00 PM
tEhNgUyeN
10
05-20-2005 04:19 AM
dr3wby
07-08-2004 04:03 PM
