How to get sticky stuff off my door?
I recently stripped my interior, but when i took of the front door panals, i found all this stick stuff that held some plastic on. How do i get it off? Can it come off?
Re: How to get sticky stuff off my door? (Downeybear11)
i tried a scraper and all it does is gets stuck to it and its VERY sticky! Any ideas?
There is an aerosol can that when sprayed makes things cold.
I'm not sure of the name, but you might ask a hardware store clerk.
This should get the goo to harden enough that you could pop it off
with your fingers easily. If you have a friend with nitrous, that could work
too, but could be more expensive.
Goot luck!!
Goot luck!!
New User
Re: How to get sticky stuff off my door? (Leejen)
Yeah that aerosol can that when you spray it makes things cold, it comes in a big blue (sometimes crome) bottle, it's called NOS (haha)
Re: How to get sticky stuff off my door? (RICEBURNER1406)
All I needed was to rub it off, now of course being in phx and we have had 100+ wheather which could have helped.
Re: How to get sticky stuff off my door? (FFSquad)
Hell yeah he is!!! Why do you think he is getting the goo off?
That is what all the kids are doing now.
BTW How much crap do you get for not being in the real FFSquad?
FFSquad..
yeah i plan on leaving them off.
jg..
no i havent wieghted them yet. ill do it later on today.
on and for the capri sun.. i kinda used it as my trash can that day
jg..
New User
man looks like you got a problem.... a sticky propblem. hit it with a heat gun. no hair dryer is gonna do it. all you need is a heat gun and a sharp edge. try that. good luck
Location: gravity rides everything...everything will fall, se GA/ne FL
1 Post
pick as much of it off as you can, you will end up with frikkin sticky hands but you only do this once. give the remaining door residue a little time and when it darkens...it will be brittle and you can easily chip or scratch it right off and just do a good wipe with windex or something and it will look like it was never there.
Rubbing a little bit of gasoline on something sticky gets it off. At least it has worked for me. don't use too much...just a little, and it should dissolve the stuff.
Kristin
'00 Civic Ex
Kristin
'00 Civic Ex
JoshuaVTEC
11
09-30-2013 06:42 PM
mstewar
12-03-2003 10:13 AM
