Kyb Agx installed
Kyb Agx installed
Just finished the install...HUGE differance.....I recomend these to everyone
To those currently running them...what settings are you guys using? I'm currently at 2 in the front, and 5 in the rear.
Re: Kyb Agx installed (b18bturbo)
3,4 huh... I was afraid that would be to tight up front...But I'll give it shot
I love how simple they made making adjustments ...
Re: Kyb Agx installed (superflea)
my agx rears just came in tuesday. tried to install them but sheared the mounting bolt
the front feels much better though with gc/agx
Re: Kyb Agx installed (eviladam)
Damn...I've been there
I had to hammer a size 13 socket on one of mine..and use a breaker bar to get it off...And the replace ment bolt is 9 friggin dollars from the dealer
New User
Re: Kyb Agx installed (DragIIcivic)
okie..i'm kinda confused sometimes:confused:...so the higher the number,the stiffer it gets or the lower the number the stiffer it gets??'coz i got mine 3 in front and 2 in the back..
How low is your car? I've heard that the AGX's don't handle drops below 2" very well. Just FYI. Good shocks overall. Great shocks for the money!
I couldn't be happier with my AGX's. I swapped out a set of 80k Tokico HP's. The G5 civic's only have a 1-4 adjustability. I run 2 all the way around. 4's all the way around is pretty wicked, but really annoying for daily use. (the old, needle following the grove of a record effect)
the directions say the warranty is void if you lower more than 1.5", mines about 2" now.
DragIIcivic: didn't you get the Integra ones instead? What size and how many washers did you need for the rear LCA to make the rear shocks fit?
Re: Kyb Agx installed (bhcvc)
Shouldn't matter if you got the ones for the Integra or 5G Civic, right?
As far as shocks go, I think part numbers should be the same.
Most other brands have the same part numbers for both Integra and Civic.
Now I'm curious too. What's the scoop Mr. DragII?
Re: Kyb Agx installed (Leejen)
The 3G teg and 5G civic have directly swappable suspension both front and rear. However, the rear shock is different on 6G civics. The tegs should fit, but I think some washers are needed.
sorry guys, i've been gone...I got the integra rears...but JC whitneys dumb ***** sent me some shocks from a eclipse..and claimed they were the correct pt #....I checked w/ kyb and confirmed they were full of ****...after I called back to JC and the girl was like (shocks....are those for a car) I was like F you guys...sent em back...and went w/ the groupbuy...$340 cost more, but much less headache.....the teg shocks are aprox 5 mil to big...not a big deal...but I'm rolling civic specific kybs now.
