WHAT ELSE CAN I DO FOR CHEAP SAFE SPEED
New User
I'VE PRETTY MUCH FINISHED MY BOLT ONS AND ADVANCED TIMING BUT I'M LOOKING FOR SOMETHING ELSE TO PLAY WITH. ANYTHING CHEAP AND SAFE I CAN DO?
New User
Re: WHAT ELSE CAN I DO FOR CHEAP SAFE SPEED (DragIIcivic)
oops. i didn't know that the caps key meat a member was mad. i usually have my caps key on all the time. i don't wanna have to worry about pressing the shift key all the time. mah bad to eveyone
Re: WHAT ELSE CAN I DO FOR CHEAP SAFE SPEED (shogokocoupe)
It's all good....now what engine do you have? if your going all motor, have you already done cam gear (s) or a Cam? Your kind of at a point where things start to get expensive if you have finished the bolt ons
New User
If you have done all bolt-ons, I am assuming no cams, do cams and cam gears if not already done. Then maybe some mild porting and polishing of the head! These should generate some power with propper tuning.
New User
i'm pretty sure now that i have to go and hook up on some cams. i think that i should just swap this motor before i drop anymore seious money into this thing..
New User
Re: WHAT ELSE CAN I DO FOR CHEAP SAFE SPEED (CROWN!)
porting sounds good. i'll have to think that one over. but i guess swapping is my next thing.
