please help-GSR swap into del sol s
I have a 95 del sol s with a d15b7 and I have been working on putting in a 95 b18c1 and am almost done but I was told that I have to use the GSR axles and they will not fit my hubs...what do I do.
I also discovered that the GSR has an extra wiring harness with three wires, white with a red stripe, blue with a red stripe, and a red wire. how do I wire this?
thanks
Rob
thanks
Rob
New User
Re: please help-GSR swap into del sol s (delsolrob)
if its the harness on the pass side its for the abs you dont need it and you have to use 94-00 integra axles they will fit in your hub
Re: please help-GSR swap into del sol s (GOT 5 ON IT)
I have the gsr axles and they are way to thick to "bolt" into the hub, my friend is about to cut them and weld my old CV assembly to the gsr axle.
hey i have a 1995 jdm gsr motor in my captiva blue del sol S and i had the same problem, i had to use Place Racing axels, very good axels and they are alot thicker then gsr axels so u will not break them, and if u do break them, they are warrantied for life and u get brand new ones from Place Racing, only problem is they are pricey( 178.00 for each axel) so thats like 360.00 for both, def worth it in my opinion
DelSol-B18
04-14-2014 07:07 AM
