b16a motor mount bolts...
Old 07-20-2002, 10:58 PM
PrecisionH23a's Avatar
Default b16a motor mount bolts...
Set up: 94 hatch with 1st gen b16a motor. Ok guys, i am missing 2 rear motor mount bolts and i need honda part #'s for them. The bolts are pictured below inside of the red circles...
First pic... looking at the rear motor mount from the drivers wheel. Located below intake manifold...
2nd pic: close up of bolt needed, bottom 19mm bolt that bolts into the tranny.
3rd pic:another close up
4th pic: Looking from passenger side front wheel. Rear motor mount bolt. Bolts into the motor mount to the block. I have the bolt as you see pictured, but i need the nut that goes on the end. I thought there was a nut welded to the motor mount, but there isnt one. Did it fall off or is there a separate nut there?
5th pic: close up of bolt
6th pic: Opposite side of nut, where i am missing a nut or either the welded on nut on the motor mount came off.
Does anyone have part numbers for these or exact thread pitch and measurements of them? Also, is this motor mount supposed to have a nut welded onto it??? Thanks for all of your help...
Old 07-20-2002, 11:10 PM
Default Re: b16a motor mount bolts... (dark lotus)
im not sure, does anyone have dimensions or the part #'s of these bolts?
218luder
05-23-2008 02:25 PM
MeanD
08-22-2004 03:39 PM
PrecisionH23a
07-24-2002 01:11 PM
Quick Reply: b16a motor mount bolts...
