6 Puck ACT problems
Old 07-21-2002, 08:50 PM
Banned
DualKnuttz's Avatar
Default 6 Puck ACT problems
The clutch did not grab the night before and when I removed the tranny this is what I saw. The teeth on the clutch completely grinded off and it did not engage with the tranny. Does anybody know the what could have caused this problem because I put the same clutch back in (a new one) and I dont want it to end up the same way. And I only drove on the clutch for like 5 months before this happened and no more than 10000 miles.
Old 07-21-2002, 08:53 PM
mingchi96
Guest
Posts: n/a
Default Re: 6 Puck ACT problems (DualKnuttz)
I would check your mainshaft also. get back to us on it.
Old 07-21-2002, 09:48 PM
Pho Real's Avatar
[QUOTE]The clutch did not grab the night before and when I removed the tranny this is what I saw. The teeth on the clutch completely grinded off and it did not engage with the tranny. Does anybody know the what could have caused this problem because I put the same clutch back in (a new one) and I dont want it to end up the same way. And I only drove on the clutch for like 5 months before this happened and no more than 10000 miles.
you were owned by a pucked clutch..... and you will be owned again in the near future
Old 07-21-2002, 09:57 PM
Pengo's Avatar
Default Re: 6 Puck ACT problems (VTEXTC HB)
yea, was there any damage on the teeth of the mainshaft on the tranny? did you receive the right clutch for you exact application? did u use a clutch alignment tool and make sure everything was aligned up perfectly?
if theres no damage to the mainshaft, then unless the clutch is made really shitty, i would have to gues it was either misaligned or the wrong one. could be something else i didnt think of yet tho. good luck finding out wat went wrong
-alan
Old 07-22-2002, 03:25 PM
Banned
DualKnuttz's Avatar
The mainshaft is ok and i got the correct clutch. The only thing that I can expect is that it the clutch should be only used for track purposes. It said right on the package "not recommended for street use" I guess I was owned by the 6 puck gang. damnit.. Another thing I noticed was that the clutch ate away at the flywheel and the pressure plate. It made a groove on it. I think i'm going to go with a street disc or something less harsh.
phatstyles
05-01-2005 05:54 PM
dan89crxsi
10-12-2004 01:32 PM
CimorelliCRX
12-15-2002 04:02 AM
Quick Reply: 6 Puck ACT problems
