Horn problem
Horn problem
The horn on my 93 civic hatchback seems to have a problem. It will work half the times i try to use it, but the other half of the times i try to use it it wont work. I can hear that clicking sound when i press the button, but thats all, no horn sound. Does anyone no what it might be? maybe a loose connection somewhere? Thanks for any help!
Re: Horn problem (CivicHB-Si)
Mine does the same exact thing. I was told it was flooded or something, I haven't really tried to fix it yet though. In plce of my horn I stick my head out of the sunroof and scream a stream of profanity...
Re: Horn problem (shermanyang)
thats what i'll probably have to do, but it might be the wiring, anyone know where the wires run so i can check them out??
just check it with a voltage thingy...to see if any power is running to it when the horn is pressed. most likely it's not the wiring. the wires are bunched up so i'm thinking you wouldn't want to go through unwrapping all that stuff. good luck man...if you lived in st.paul i'd give you a few horns since i've got like 10 of em.
