B18 won't start
B18 won't start
Hey guy need some help, I just finish doing a swap B18 OBD1 into a 92 Civic Si. The motor cranks but won't start. Some of my friends said it's wiring. And the only thing I checked out was no fuel to the motor. What's the deal? I used the B18 engine harness, didn't wire anything. Am I suppose to? thanks
Solbros Owns Me
Re: B18 won't start (si foo)
Are you saying there's NO fuel!!! when you turn the ignition on, you don't hear the fuel priming, correct? If so, go back and make sure the wiring is all correct and you have all the plugs together...that sucks
maybe your fuel pump is dead? but it seems like it would be the wiring to the fuel pump..... your fuel filter may also need to be changed if your pump is working.
Re: B18 won't start (DelSol808)
I'm thinking it might be the fuel but ppl told me it's wiring...I thuogh it's plug and play on OBD1. Is there wiring involed with the swap?
