Limited Slip Questions...
I tried the search and it came up with no results for my specific question (and I searched properly I hope ).
I am in the process of purchasing a B18C1 which apparently has LSD. My question is, is there a way to tell this is actually a LSD before I install it with a visual check?
Thanks guys
Andrew
HT Rules
Thanks guys
Andrew
HT Rules
Former Moderator
Re: Limited Slip Questions... (DJ Nokturnal)
Look through the differential hole where the axles stick into the tranny.
If you can look all the way through with nothing blocking your view, it HAS LSD.
If when you look through you see a pin or a "bar" sticking diagonally through the hole, then it is NOT an LSD.
Re: Limited Slip Questions... (Spade)
awesome... thanks for the awesome replies...
last rookie statement....
at which step of the install are these pics taken.... are these taken while the engine is attached to the tranny and the axels are just not installed?
am i close?
hehehe
am i close?
hehehe
Former Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ Nokturnal »</TD></TR><TR><TD CLASS="quote">awesome... thanks for the awesome replies...
am i close?
hehehe</TD></TR></TABLE>
You'll see the diff pin (or hopefully not) when the tranny is on or off the engine.
The only way you won't see it is if there are axles or inner joints attached in there.
am i close?
Unceasing Measure
am i close?
Wow, a noobie with promise . Stick around for a while, you seem like good people .
am i close?
Re: Limited Slip Questions... (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">
Wow, a noobie with promise . Stick around for a while, you seem like good people .</TD></TR></TABLE>
Seems like a good person. Damn Ohio redneck.
awh you're making me blush
i soon hope to contribute instead of asking moronic rookie questions...
You searched before asking the question... When you asked you use punctuation and proper english... to rookies like you...
I have a noob question while on the subject. I was wondering what kind of LSD comes on the stock S80 ITR trans? I thought there were different kinds and I was curious which one this trans has.
Re: (Motts)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Motts »</TD></TR><TR><TD CLASS="quote">I have a noob question while on the subject. I was wondering what kind of LSD comes on the stock S80 ITR trans? I thought there were different kinds and I was curious which one this trans has.</TD></TR></TABLE>
I believe a helicial type.
Re: (Skyllz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skyllz »</TD></TR><TR><TD CLASS="quote">It should look something like this...
Just finished changing synchros in my R tranny </TD></TR></TABLE>
To me, that is sexy.
Re: (Spade)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spade »</TD></TR><TR><TD CLASS="quote">
To me, that is sexy.</TD></TR></TABLE>
So I'm not the only one that thinks that...
Re: (acuracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracing »</TD></TR><TR><TD CLASS="quote">
So I'm not the only one that thinks that...</TD></TR></TABLE>
I have to admint it does look ALOT harder then it was.
Only time consuming and having to reassemble the main shaft 5 times due to not putting everything back like it was supposed to be. otherwise all ok!!!
Re: (acuracing)
No you're not.
No you're not.
Re: (Spade)
You and me both!
You and me both!
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">
You and me both!</TD></TR></TABLE>
You guys need to get out of the garage more! Those oil, coolant, fuel, and tranny fluid fumes are clouding your juedgement!
cool, where did you buy the syncros from? how much was the whole rebuild? like gaskets, misc seals, clips, syncro rings, all that good stuff.
Re: (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder »</TD></TR><TR><TD CLASS="quote">
You guys need to get out of the garage more! Those oil, coolant, fuel, and tranny fluid fumes are clouding your juedgement! </TD></TR></TABLE>
LoL....just cause we do our own work, unlike someone I won't meantion.
J/P
J/P
Re: (tek_civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tek_civic »</TD></TR><TR><TD CLASS="quote">cool, where did you buy the syncros from? how much was the whole rebuild? like gaskets, misc seals, clips, syncro rings, all that good stuff.</TD></TR></TABLE>
well... 800$ Can. later...
Synchros for 1-2 3-4
A tube of Permatex Ultra-Grey
2 litres of Honda MTF
Thats all folks. Synchros are a bitch to buy here, next time i'll order them threw the US, even with exchange and duties and taxes, it'll be cheaper.
It's only time consuming. That's all.
Re: (Spade)
You have not seem my GF working on her car or her KAwasaki 636 yet... *drooling*
And no you guys wont have pics
CRX A4
04-05-2003 04:04 AM
