Will the rear bumpers swap out on 2dr & 4dr 92-95 Civics?
Someone backed into my stepsons 93 4dr Civic & left the seen. So we are tring to fix it as cheap as poss.
I got a rear bumper,tail light, & the metal pc under the tail light off of a 2 dr.
The metal pc will not work. I would like to know if the bumper will work before we pull the old one off because once its off it will not go back on.
TIA
TIA
Re: Will the rear bumpers swap out on 2dr & 4dr 92-95 Civics? (NC-B17A)
If you can, get under the car and look for the part number molded inside the rear bumper cover and see if it matches EXACTLY the bumper you have.
Re: Will the rear bumpers swap out on 2dr & 4dr 92-95 Civics? (Outrun)
when i had my body kit (a LONG time ago), i sold me rear bumper to my friend who had a four dr and it bolted right up...i have a 2 dr coupe...i'm sure it fits
if i remember correctly, the rear bumper/tailights are interchangeable between the coupe and sedan; while the entire front end are interchangeable between the coupe and the hb...
Re: Will the rear bumpers swap out on 2dr & 4dr 92-95 Civics? (Infinity_Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Infinity_Racer »</TD></TR><TR><TD CLASS="quote">when i had my body kit (a LONG time ago), i sold me rear bumper to my friend who had a four dr and it bolted right up...i have a 2 dr coupe...i'm sure it fits
if i remember correctly, the rear bumper/tailights are interchangeable between the coupe and sedan; while the entire front end are interchangeable between the coupe and the hb... </TD></TR></TABLE>
I'm pretty sure about the coupe and sedan rear ends but I'm not sure enough to guarandamntee it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outrun »</TD></TR><TR><TD CLASS="quote">
I'm pretty sure about the coupe and sedan rear ends but I'm not sure enough to guarandamntee it! </TD></TR></TABLE> I'll Guarantee it for you. Coupe's and Sedans share the same rear bumper, taillights, and trunk from 92-95
Re: Will the rear bumpers swap out on 2dr & 4dr 92-95 Civics? (Echo7847)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 »</TD></TR><TR><TD CLASS="quote"> I'll Guarantee it for you. Coupe's and Sedans share the same rear bumper, taillights, and trunk from 92-95 </TD></TR></TABLE>
The trunk is definitely different but im not sure about the lights. I would guess that the rear bumper is different as well.
Yeah that is wrong. Sedan has shorter trunk and only aftermarket tails fit between the two. The back bumper is NOT the same. I have a two door back bumper on my foor door and it bows out at the sides. It's horrible which is why im searching for a four door back bumper.
Re: (Dream)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dream »</TD></TR><TR><TD CLASS="quote">Yeah that is wrong. Sedan has shorter trunk and only aftermarket tails fit between the two. The back bumper is NOT the same. I have a two door back bumper on my foor door and it bows out at the sides. It's horrible which is why im searching for a four door back bumper. </TD></TR></TABLE>
Bullshit, theyre the exact same thing. 2/4dr lights are interchangable I've switched them myself.
Edit: I just checked the parts numbers and theyre the exact same on the rear bumper and tail lights for the coupe and sedan. The trunk lids have diff part #'s.
IT'S ME DAVID
11
06-01-2006 12:21 AM
