Wheel seized onto hub
I bought this 95 honda civic EX coupe about a month ago and I'm changing the front brake pads. When I jacked up the car, the front right wheel is seized onto the hub. The lug nuts come off, but the wheel wont budge. I sprayed some penetrating lubricant on it and left it overnight, but it still wouldn't budge. Some guy that works on big rigs said that when that happens to one of his trucks, he kicks it loose, i.e. He kicks the top of the tire, bottom, right, and left as hard as he can to loosen it up. Any thoughts on this or suggestions for alternate courses of action? Thanks, guys.
Re: Wheel seized onto hub (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">i kicked my wheel...kick the top of it...the whole wheel will eventually budge loose</TD></TR></TABLE>
You can also use a rubber mallet. I typically just use the old "leg" tool, also.
Re: Wheel seized onto hub (Sushiboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sushiboy »</TD></TR><TR><TD CLASS="quote">
You can also use a rubber mallet. I typically just use the old "leg" tool, also.</TD></TR></TABLE>
Oh yes... The "leg" tool works wonders Just kick it man, It'll come off.
jus f0 dekarayshunZ
Re: (dantastic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dantastic »</TD></TR><TR><TD CLASS="quote">just make sure u dont kick the car off the damn jack/stand when u do</TD></TR></TABLE>im guessing you did that...yea use a rubber mallot or your foot...it should come off fairly easily
Re: (ciRcuitSi y0!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ciRcuitSi y0! »</TD></TR><TR><TD CLASS="quote">im guessing you did that...yea use a rubber mallot or your foot...it should come off fairly easily</TD></TR></TABLE>
never have, but im a civil engineer, and i study support structures alot =P
Re: Wheel seized onto hub (BlueHatch00)
Got the damn wheel off! Haha. I had to get the wheel off to change my brake pads and it was about damn time to change those things, too. Thanks a lot guys!
Re: Wheel seized onto hub (BlackJoker)
sometimes if kicking doesnt work ive had to put the car on the ground and drive on it till it pops off ... never happened to me with a honda though
Re: Wheel seized onto hub (CivicFerioSiR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioSiR »</TD></TR><TR><TD CLASS="quote">sometimes if kicking doesnt work ive had to put the car on the ground and drive on it till it pops off ... never happened to me with a honda though</TD></TR></TABLE>
What? Just let it fall off?
HT Black Ops
Remid me to NEVER let you TOUCH my car!!
Wait a minuet, you drive your car around without any lug nuts to get the wheel off?
Re: Wheel seized onto hub (Dead Puppy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dead Puppy »</TD></TR><TR><TD CLASS="quote">Yikes that guy is fricken NUTZ!!!!!!!!!!!!</TD></TR></TABLE>
I agree!
I agree!
Re: Wheel seized onto hub (Relix)
oh come on guys. you just let the car back down and turn the wheel all the way and drive a few inches back and forth and it just pops partially off. the wheel doesnt fall off all the way!! the threads stop it from going all the way... sometimes its the only alternative you have!
D Tranny Guru
but doing that with the wheel "loose" just destroyed 4 wheel studs,
jack up car, loosen the lug nuts, kick the tire.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicFerioSiR »</TD></TR><TR><TD CLASS="quote">oh come on guys. you just let the car back down and turn the wheel all the way and drive a few inches back and forth and it just pops partially off. the wheel doesnt fall off all the way!! the threads stop it from going all the way... sometimes its the only alternative you have! </TD></TR></TABLE>
NO, NEVER.
NO, NEVER.
