ODB II to OBDI - Which ECU Should I get
Old 03-10-2004, 11:26 AM
quicksol95's Avatar
Default ODB II to OBDI - Which ECU Should I get
I have a 98 Civic Ex auto.
I am going to convert it to a OBDI car and I was wondering which ecu I should get.
Thanks
Old 03-10-2004, 11:27 AM
Anthonyl469's Avatar
Default Re: ODB II to OBDI - Which ECU Should I get (slowsohccivic)
p28
SOHC_MShue's Avatar
automatic p28 ecu. I wouldn't waste my money though...do a manual conversion first.
Old 03-10-2004, 11:31 AM
quicksol95's Avatar
Default Re: ODB II to OBDI - Which ECU Should I get (SOHC_MShue)
i like my auto
Old 03-10-2004, 11:33 AM
SOHC_MShue's Avatar
fine then...be slow
Old 03-10-2004, 11:34 AM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowsohccivic &raquo;</TD></TR><TR><TD CLASS="quote">I have a 98 Civic Ex auto.
Thanks</TD></TR></TABLE>
why?
Old 03-10-2004, 01:03 PM
sinatra's Avatar
Default Re: ODB II to OBDI - Which ECU Should I get (Kamin)
you are modding an automatic why? Anyway...um auto ecu...uh...you are modding an automatic why? Auto p28 is my final answer. PLEASE reconsider
Old 03-10-2004, 01:08 PM
RyanEJ8's Avatar
Convert to manual!
Old 03-10-2004, 06:59 PM
Kamin's Avatar
Default Re: ODB II to OBDI - Which ECU Should I get (sinatra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sinatra &raquo;</TD></TR><TR><TD CLASS="quote">you are modding an automatic why? Anyway...um auto ecu...uh...you are modding an automatic why? Auto p28 is my final answer. PLEASE reconsider</TD></TR></TABLE>
if he wants to mod an auto let him
im trying to figure out why he wants to convert to OBDI, there are no advantages for his stock car and it will only cause havok when he tries to go to emissions.
Old 03-10-2004, 07:08 PM
jdmjackol's Avatar
yah why r u converting your obd2 to obd1? what is the cause for some smog headache in the long run.
Old 03-10-2004, 07:26 PM
Bunger's Avatar
Default Re: ODB II to OBDI - Which ECU Should I get (EK-JU)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK-JU &raquo;</TD></TR><TR><TD CLASS="quote">yah why r u converting your obd2 to obd1? what is the cause for some smog headache in the long run.</TD></TR></TABLE>
Get a conversion harness and you can switch back in 2 minutes. OBD-I you can chip easily and make decent power gains on even slightly modified motors.
Old 03-11-2004, 12:09 AM
iH8RICERZ's Avatar
dont even waste your money or time........no point converting to obd 1 when you cant really do much if you want to stick w/ auto.....
Old 03-11-2004, 03:35 PM
PHiZ's Avatar
Default Re: ODB II to OBDI - Which ECU Should I get (Bunger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bunger &raquo;</TD></TR><TR><TD CLASS="quote">
Get a conversion harness and you can switch back in 2 minutes. OBD-I you can chip easily and make decent power gains on even slightly modified motors.</TD></TR></TABLE>
-PHiZ
Old 03-11-2004, 03:54 PM
RyanEJ8's Avatar
Not everyone has smog testing like those of you in Cali.
I've NEVER had to have a car smog tested. I live in Florida.
Old 03-12-2004, 10:32 AM
jdmjackol's Avatar
Default Re: ODB II to OBDI - Which ECU Should I get (RyanCivic2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RyanCivic2000 &raquo;</TD></TR><TR><TD CLASS="quote">
I've NEVER had to have a car smog tested. I live in Florida.</TD></TR></TABLE>
damn i should move there
Old 03-13-2004, 01:15 PM
sirjeff's Avatar
it sure is an auto.
if it was manual, you would have all asked what his mods were (or bitched at him to search).... how do you know he doesnt have a b18 or h22 with a nice i/h/e setup ready for an ecu??
heres an auto worth mentioning
http://www.aj-racing.com/proje....html
i met the car at a local club meet down here
not that my post helps his question or anything.....
Old 03-13-2004, 01:20 PM
IS3Fifty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">automatic p28 ecu. I wouldn't waste my money though...do a manual conversion first.</TD></TR></TABLE>
Post didnt need to go any further..... you skipped a step.
"I like my auto": why would you even put a post on the board like this then. You have to use the ecu you have. theres no swapping. unless you go down on the spectrum, where you wont be able to engage Vtec because the ecu isnt programmed for it. You have a SOHC motor, 1. cant use a DOHC ecu 2. You have an Automatic tranny, cant use a manual tranny.
civicfrog
02-04-2013 04:00 AM
7rrivera7
02-10-2007 11:42 AM
Jan in Omaha
10
05-12-2005 04:43 PM
dubbedcorde
12
12-05-2004 07:59 PM
turbotime
11-29-2003 03:53 PM
Quick Reply: ODB II to OBDI - Which ECU Should I get
