sparco harness install help?
Hey, I have some sparco 3 point bolt-in harnesses in my hatch with sparco sprints and sliding sparco seat brackets. I have them bolted to the back frame at the right angle and all of that okay, but the problem is, I can't get them tight enough on the sides, but they're bolted to the places they are supposed to be on the sparco rails...so if anyone had any input on what to do it would really help. Thanks.
Re: sparco harness install help? (CandyRedHatch)
you bolted both lap belt mounts to the seat rail? I thought one is supposed to go through the stock belt location near the door. Are you adjusting the belt to the tightest position?
Re: sparco harness install help? (SoichiroH)
Sorry yeah, I have the outer sides bolted in to where the stock belt was and the inner sides bolted to the rail, and yeah even when tightest, the inner side straps are still too loose.
