CTR SRS steering wheel problem....
...I just installed my steering wheel and now the horn doesnt work. I hooked the wire up to the connector for the horn and now all i hear is a click from under the dash near the fuse box. Im thinking that maybe i blew a fuse or something but i havent checked yet. Is there anything else that could be wrong?
Re: CTR SRS steering wheel problem.... (veggiemaster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by veggiemaster »</TD></TR><TR><TD CLASS="quote">did you flip the wires?</TD></TR></TABLE>
No....the wires both connected to make on wire. Then i just clipped that wire into where the original horn wire was.
Re: CTR SRS steering wheel problem.... (EKcoupe99)
you make sure the horn is plugged up, just pop the hood and it is below the Rad support. you can get it off easy, then just take the two wires and touch them to your battery to see if it is the horn or the wiring somewhere else. you horn may have taken a **** on you.
Re: CTR SRS steering wheel problem.... (kidkombo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kidkombo »</TD></TR><TR><TD CLASS="quote">u broke you your cable reel... i did the same to mine</TD></TR></TABLE>
Can you explain some more?
Thanks for the help
Thanks for the help
Your cable reel is a disc thingy behind your steering wheel. It rotates when you turn the wheel. Coming from the cable reel are wires for your SRS, horn, and cruise plugs. The group of wires connect to your cable reel via a plug held on by tape. To me, it looks like the plug is not held in very good.
What kind of steering wheel did you put in? I heard the JDM wheels have a horn problem with the USDM cars. I think you need to rig it somehow.
Re: CTR SRS steering wheel problem.... (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Your cable reel is a disc thingy behind your steering wheel. It rotates when you turn the wheel. Coming from the cable reel are wires for your SRS, horn, and cruise plugs. The group of wires connect to your cable reel via a plug held on by tape. To me, it looks like the plug is not held in very good.
What kind of steering wheel did you put in? I heard the JDM wheels have a horn problem with the USDM cars. I think you need to rig it somehow.</TD></TR></TABLE>
Thanks for the info. I put in a CTR SRS wheel
llteddy4playll
08-17-2007 01:54 PM
XxSOHCDriVerxX
10-01-2003 06:24 AM
