CEL Code After Air/Fuel Gauge Install
Old Jul 14, 2004 | 11:18 PM
g2_boosted's Avatar
Default CEL Code After Air/Fuel Gauge Install
Hey Guys, I recently installed an Autometer Air Fuel Gauge. We tapped it into the O2 sensor and after we installed it I reset the Ecu. So after letting the car warm up i got a CEL code right when it finished warming up. I dont have a cel checker so i dont know exactly what the problem is but i assume is has something to do with the O2 sensor. I heared that ur supposed to run the gauges ground to the negative battery side? Is this true? I hooked the negative up so it shared my cd players ground...
Thanx
Old Jul 15, 2004 | 03:50 PM
g2_boosted's Avatar
Default Re: CEL Code After Air/Fuel Gauge Install (g2_boosted)
bump
Old Jul 16, 2004 | 11:00 AM
g2_boosted's Avatar
anyone?
Old Jul 16, 2004 | 12:03 PM
dunkd's Avatar
what year is ur car?
when i put in my a/f gauge i ran it to the only purple wire on the long ecu plug, then grounded to a nut under the dash, and ran the power wire to the radio fuse.
my car is obd1 gsr so might be different...
Old Jul 16, 2004 | 04:02 PM
g2_boosted's Avatar
Default Re: (dunkd)
its for a 2000 Civic Si (Canadian Version) so its an EX for americans.
Old Jul 16, 2004 | 05:51 PM
SpdFrk's Avatar
U did tape it into the primary instead of the secondary right?
Old Jul 16, 2004 | 05:53 PM
GSRrR's Avatar
read this to learn how to check the CEL. dont need a checker, just a piece of wire.
https://honda-tech.com/zerothread?id=682412
Old Jul 16, 2004 | 06:28 PM
dunkd's Avatar
Default Re: CEL Code After Air/Fuel Gauge Install (GSRrR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSRrR &raquo;</TD></TR><TR><TD CLASS="quote">read this to learn how to check the CEL. dont need a checker, just a piece of wire.
https://honda-tech.com/zerothread?id=682412</TD></TR></TABLE>
thats for obd1 cars.
Old Jul 16, 2004 | 07:40 PM
Turbogixxer's Avatar
Default Re: CEL Code After Air/Fuel Gauge Install (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd &raquo;</TD></TR><TR><TD CLASS="quote">
thats for obd1 cars.</TD></TR></TABLE>
The connector is in the same place for OBD2.
Old Jul 17, 2004 | 06:20 PM
g2_boosted's Avatar
Ok, Checked what code im getting and its Code 1. Primary 02 Sensor, Changed the ground from the gauge to the battery, reset the ECU, and still the same CEL code, What could be the problem?
Old Jul 17, 2004 | 06:29 PM
dunkd's Avatar
what o2 wire did u tap into?
Old Jul 17, 2004 | 06:34 PM
g2_boosted's Avatar
Umm the White Wire
Old Jul 18, 2004 | 08:10 AM
dunkd's Avatar
there was two white wires right? it sposed to be the thicker one.
brockscivic
Oct 5, 2005 10:47 AM
junkyardRx
Apr 21, 2004 08:40 AM
pr0jektdc2
Oct 2, 2003 12:13 PM
T3T495GSR
May 18, 2003 08:23 PM
pbwill
Dec 16, 2001 04:27 PM
