car won't start
car won't start
ok, today i was leaving work and my car wouldn't start. I gave it a min. and it started right up but would idle at 100 rpms, almost staling. i thought it was my IACV so i cleaned it out, and now it doesn't even turn over.
it is...
1. trying to turn over
2. not a fuel problem ( i can smell fuel after i try to start car)
3. can't check my spark plugs because my spark plug socket is to fat to fit in the spark plug holes.
i have a 93 si hatch with stock D16z6 w/178,xxx miles no mods,
my questions is .. would a bad IACV cause my car not to turn over? TIA
it is...
Re: car won't start (Blindstuff)
fuel relay did that to me...it will idle really low and almost die. there is a wire to the left of where the fuses are. its kinda thick and covered with some kind of wrap. tug on it a couple times and see if your car starts...i have to do it almost daily
Re: (Jimmy)
thanks a lot i forgot about that ... would that make my horn not work?? cuz it hasn't worked since i have had it.. which is 2 weeks
Re: (photec2)
turns out it was my dizzy.. i picked up a spare one from a friend (photec3) and swapped the ignition coil and bingo. that was the problem
Apple395
08-02-2013 03:11 AM
the.hamburglar
04-21-2007 12:45 PM
sohcVTEK
06-18-2006 08:44 PM
