Going to do y7/y8 mini me swap.
Re: Going to do y7/y8 mini me swap. (goofyej6)
you also need a d16y8 manifold that matches the obd of the head (obd2a vs obd2b) also the intake and exhaust mani gaskets, get a two pin iacv and also a d16y8 throttle body. Make sure to do the two step iacv fix. Wire the knock sensor with oem shielded grounded wire, and also put a resistor for the fuel tank pressure sensor or else a code 91 will happen. Good luck.
Re: Going to do y7/y8 mini me swap. (DewMota)
then dont change your old *** water pump watch it fail and have an overheating system...
Please stick that caplock key in your ***. thanks.
I'm only trying to save you from more work down the line.
Modified by Drew95eg at 7:55 AM 7/15/2004
Re: Going to do y7/y8 mini me swap. (Drew95eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drew95eg »</TD></TR><TR><TD CLASS="quote">then dont change your old *** water pump watch it fail and have an overheating system...
Please dont be gay unless your name is dewmota....</TD></TR></TABLE>
WERD.
Replacing the water pump is for preventative maintanence reasons only. You're going to have the engine apart, so why not put in a new pump and while you're in there, a new tensioner pulley as well.
WERD.
Re: (Tokyo_X-treme_Racer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tokyo_X-treme_Racer »</TD></TR><TR><TD CLASS="quote">Im wondering, why do a mini-me when you can just get a whole y8 setup?</TD></TR></TABLE>
more pain more gain, actually i was a minime but i DE minimed and got a y8 tranny and trust me, a dx with an ex tranny is faster than a dx with an ex head
yea that's what i was thinking too but i got a good deal on the head. getting the tranny within a month =D 15 seconds here i come i hope!
SOHC_civic_si
05-04-2008 08:50 PM
88hondahatch
02-03-2004 07:26 PM
