problems with B18C5 / EG Swap?
I just purchased a B18C5 (ITR) engine package from Street Imports to go into my 92 civic hatchback (5spd). I was just wondering what types of problems do you guys think i'll run into. If you guys could help me by posting a list of problems that may arise during this swap, and how I may fix them. This way i'll be prepared for the worst...if there is any problems. Mostly problems with the OBD is what confuses me. Do i need different harnesses, if so where do I find them. Thanks again guys
Re: problems with B18C5 / EG Swap? (EGB18)
you should only need the jumper harness to run the ITR ecu
everything else is plug and play(besides running the extra wires for knock sensor, VTEC, etc)
Re: problems with B18C5 / EG Swap? (taqman15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by taqman15 »</TD></TR><TR><TD CLASS="quote">you should only need the jumper harness to run the ITR ecu
everything else is plug and play(besides running the extra wires for knock sensor, VTEC, etc)</TD></TR></TABLE>
IMO, you'd be better of getting a P28 chipped to run it, both would be about the same, but the OBD I computers have more tuning options, and it will plug right in.
Re: (92WhiteEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92WhiteEG »</TD></TR><TR><TD CLASS="quote">You shouldnt have to run any extra wires b/c all 92 civics already came with the VTEC wiring harness</TD></TR></TABLE>
ALL 92+ civic? are you sure? I disagree.
Re: (redlinetuning)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redlinetuning »</TD></TR><TR><TD CLASS="quote">
ALL 92+ civic? are you sure? I disagree.</TD></TR></TABLE>
he didnt say 92+ he said 92...
a 92 four door dx i helped wire didnt need any wiring besides the knock sensor!
TSPeed Factory
Re: (degooser)
remember to put the rear motor mount in before the motor. if you forget to, it'll be a bitch to get it in if the motor is already dropped.
that's if you do it the floorjack method.
Greg456
04-26-2004 04:09 PM
SPOONfdEK
06-12-2003 06:39 AM
43MA
11-06-2002 08:46 PM
