EP brake callipers on an EG?
Tried the search but with no luck
Anyone know if EP3 brakes will will fit an EG. have been offered a good deal on a set of front and rear callipers with brackets. I have a non ABS EG with disc conversion, so 4 stud, 240 vented front, solid rears. I have a set of hubs to suit 260mm callipers coming, but need to find if these might work
Cant find the specs on the web, so anyone know what the spec of the 01> Si brakes are?
hoping they are 260mm up front, 240ish rear with the right calliper bolting.
Anyone tried/done this?
Re: EP brake callipers on an EG? (futuresi)
Might try it, not sure about the riscs of being left with a set of callipers that only fit new cars though, they wont be needed for a while
main thing i am worrying about is the rear calliper to trailing arm fit?
Anyone know where i can find disc and pad specs for 01> civics, that would help, pretty sure the discs are the same but pad specs would help figure it out
Re: EP brake callipers on an EG? (CivicESi)
can anyone point me to any disc and calliper specs for the EP civics, 1.6, 1.7 and 2.0
Ideally does any know if the hole centres and rear discs are the same as an EG trailing arm?
any help appreciated, as the 01' civic isnt big over here except in CTR form , so very little tech info=(
slowturbocx
05-05-2005 02:53 PM
rasinhell
35
01-17-2005 06:53 PM
