main relay
Old 05-30-2013, 02:30 PM
greyEG's Avatar
Default main relay
Hey today i was testing coils on my distributor. then after testing the 2nd coil i had. i tried to turn on the car and it would not start. starter cranking etc. i had enough battery juice i checked with multimeter.
and i did not hear my fuel pump prime or the main relay click. After about 30 minutes went back. I tapped my main relay few times, heard it click and the car turned on.
main relay likely cause? or could it be a fuel pump gone bad?
Old 05-30-2013, 03:10 PM
Master Ninja
Eddie's Avatar
Default Re: main relay
Check both?
Old 05-30-2013, 03:53 PM
greyEG's Avatar
how do you check the fuel pump?
Old 05-30-2013, 03:54 PM
The Grumpiest
grumblemarc's Avatar
Put power to it directly.
Old 05-30-2013, 06:58 PM
innes887's Avatar
does your check engine light come on then go off when you dont hear the fuel pump?
Old 05-30-2013, 07:01 PM
DELuth's Avatar
Unless the pump is aftermarket, the pump is probably fine. Honda pumps rarely fail. Main relays of that style fail regularly.
eta: Just fix yours
oresama
29
10-30-2020 12:02 AM
EJ8CIVIC
07-07-2015 03:47 AM
jerome^galon
01-04-2012 07:03 PM
civic08
03-14-2010 09:26 AM
Quick Reply: main relay
