I found an automatic engine.. but i have 5sp.
ok i found a new engine for my car ( i squished a rod ) and its a y8 auto. im putting my manual tranny on the engine..
but the y8 comes out of an auto.
what will i need to do to make that work in my 5spd. p2p ecu? and my 5sp. harness?
plz help
-cory
plz help
-cory
Risky Business
Re: I found an automatic engine.. but i have 5sp. (dohcbag)
wait, you blew up your manual Y8 and you found an automatic Y8?
Just use the clutch/FW/trans from your blown motor in the new one...
yeah, i have the 5sp tranny and everything...
i heard that automatic throttle bodys were different. is this true?
and i just keep my 5sp ecu and wiring harness right?
Re: (2FAST4U831)
Just to let you know that their is no such thing an automatic engine.
The transaxle is a seperate component in the powertrain products, and a transaxle could be automatic or manual.
But as far as if the transaxles could be swapped for those engines I would say yes, most likely they could.
Re: I found an automatic engine.. but i have 5sp. (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">wait, you blew up your manual Y8 and you found an automatic Y8?
Just use the clutch/FW/trans from your blown motor in the new one...</TD></TR></TABLE>
well said, i have an automatic JDM B16A SIR II motor with a GSR tranny.....use your old ****
* B A N N E D *
1 Post
Re: I found an automatic engine.. but i have 5sp. (zer0_2_6ixty)
ATTN: Automatic and manual ENGINES may not be 100% identical. Example: The intake manifold. On the y8 MT engine, has the IACV ON the manifold. on the auto, its integrated with the TB. You should be ok though. If your just swapping out the block, I see no problems, but check ahead. Are you reusing your intake and exhaust manifolds and transmission?
Re: I found an automatic engine.. but i have 5sp. (Redline96LX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX »</TD></TR><TR><TD CLASS="quote">ATTN: Automatic and manual ENGINES may not be 100% identical. Example: The intake manifold. On the y8 MT engine, has the IACV ON the manifold. on the auto, its integrated with the TB. You should be ok though. If your just swapping out the block, I see no problems, but check ahead. Are you reusing your intake and exhaust manifolds and transmission?</TD></TR></TABLE>
well stated. he isnt doing a auto-manual conversion for the few of u who somehow interpreted that. the guy blew his manual d16y8 and is replacing it with a d16y8 that came from an automatice vehicle. here are the parts id use from your blown engine.
manual tranny, blown engine flywheel and clucth (ur auto engine wont have theses), wiring harness, intake manifold (w/ throttle body), the ecu that came in your car, and exhaust manifold/header from your blown engine (whichever u may have)
* B A N N E D *
1 Post
Re: I found an automatic engine.. but i have 5sp. (LSturboEH2)
Can anyone confirm identical blocks? Auto tranny engines idle 50rpm higher, but that may the ECU or TB, i dont know. Id assume with the same block, put a MT on, itll idle right at 620, either way 50rpms shouldnt be bad.
SPITVENOM67
04-05-2012 06:10 AM
03akkord5spd
02-21-2007 10:07 PM
