LS/VTEC TIMING
LS/VTEC TIMING
I was wondering if theres any suggestion to timing a LS/VTEC setup without dyno runs. The engine currently has:
JDM B16 head
AEM adj. Cam Gears
Integra Type R intake manifold
headerback exhaust
unorthidox pulleys
ngk plugs and wires
aem fuel rail w fuel press. reg.
intake
vtec kicks in at 4400rpms
safc (not tuned)
B18B block
JDM B16 head
AEM adj. Cam Gears
headerback exhaust
unorthidox pulleys
ngk plugs and wires
intake
safc (not tuned)
B18B block
Risky Business
Re: LS/VTEC TIMING (HondaVTEC93)
Just keep it at stock until you're dyno'ed...cam gear timing only adds 2-3 HP after A/F tuning anyways.
Ignition timing keep at 16 degrees.
Re: LS/VTEC TIMING (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Just keep it at stock until you're dyno'ed...cam gear timing only adds 2-3 HP after A/F tuning anyways.
Ignition timing keep at 16 degrees.</TD></TR></TABLE>
I concur....
I concur....
hey man i also have a 16a head and a ls bottom end with some other things.. witch water pump did u go with a used the b16 and a b16 tiiming belt and it times out right, but i have the skunk gears just for back up.
Re: LS/VTEC TIMING (mugencivic99)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mugencivic99 »</TD></TR><TR><TD CLASS="quote">hey man i also have a 16a head and a ls bottom end with some other things.. witch water pump did u go with a used the b16 and a b16 tiiming belt and it times out right, but i have the skunk gears just for back up.</TD></TR></TABLE>
You can't use a b16 timing belt on an lsvtec. It wont fit, you need a gsr or itr belt. And definitely use the VTEC water pump and oil pump.
Re: LS/VTEC TIMING (WAFFLES)
everything runs right, the car runs faster cause i retarded the VTEC cam (exhaust cam on the jdm b16a's, intake on the newer si's) 4 degrees and advanced the intake cam 4 degrees and its running much better than at a top dead 16 degrees. and yes the water pump was changed over, and the timing belt is integra i believe
not yet i know it changes w cam timing, but i ran out of time, top end is good at 4400 when vtec engages and torque's still strong surprisingly for a honda...last time i checked the ignition timing it was dead center, we'll see this time...i know i can get more out of this motor.
